create flat pattern
create flat pattern
create flat pattern
I need to create this part using sheet metal to be able to generate the flat pattern. The thickness is 12 Ga. My experience with sheet metal is not quite large yet. Please help!!
RE: create flat pattern
You will not be able to get a flat pattern from this using the  Sheet Metal module. The part you show would involve material deformation (stretching & thinning) of the "rim" features. SW does not have that capability.
You will have to create a separate 'flat'.
cheers
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
I'll confirm what CBL said.  It's true.
Windows 2000
P4 2.40 GHz
Video Card -
  Manufacturer: NVIDIA Corporation
  Card: Quadro4 900 XGL/PCI/SSE2
  Driver: 6.14.10.7184
