Anybody ever use the 3d stereo effects in SW2006?
I was reading an article about 3d stereo technology with shutter glasses and it looks pretty cool, but I wonder how good it actually works, anybody experience this?
RE: Anybody ever use the 3d stereo effects in SW2006?
I'm leaning towards the "novelty" side of things, and perhaps even a cool way to get a wicked headache ;)
phreaq
Has anyone seen my brain today? (^_^)
www.phreaq.net
- Dunc
Learn more about their technology here...
www.fakespace.com
Two leaders in stereo shutter technology are Stereographics and NuVision.
Stereographics is the leader in shutter technology, nuvision makes an acceptable knockoff.
and did the models really pop out of the screen when viewing with the shutter glasses?
I heard you need a CRT monitor with at least a 120hz refresh rate because the shutter glasses will half that so you are really only seeing 60hz refresh rate..
how is active better and different?
do you think using shutter glasses in the above setup like I have would result in a better 3d image than you get at those iMax 3d thearters? I remmber once seeing the movie "The Birds" in one of those thearters in Disney Land and it was incredible, looked like the birds were actually flying around you. But I only had to wear those cheap flimsy glasses..
by the way, if you enable the 3d Stereo plugin for Solidworks, would it make the screen look all blurry? so the only way to see the screen the right way is through 3d shutter glasses?
You won't see a blurry screen. If you have the proper equipment that can display a active stereo image, then you will see two images slighty seperate from each other. For this too look like a 3d sterescopic image then you must have the eyewear to turn off/on each eye.
Maybe things have changed since then.
