Chemical Compatibility Study on Viton & HFE71IPA
Anyone has perform any chemical compatibility study on Viton O-Ring soak in HFE71IPA ?
Will there be swelling?
Will it contaminate the solvent?
Can I soak Viton O-ring in HFE-71IPA?
Thanks.
Thanks.
RE: Chemical Compatibility Study on Viton & HFE71IPA
My experience with Viton is that is is highly chemical resistant, except it is not happy with chemicals bearing acetate radicals, amines, and it swells a little in water.
There are a LOT of Viton recipes available even from DuPont, and there is probably an optimal formulation for your HFE-71IPA stuff.
Metal Plastics Elastomers
Aluminum Acrylic Butyl Rubber
Copper Polyethylene Natural Rubber
Carbon Steel Polypropylene Nitrile Rubber
302 SS Polycarbonate EPDM
Brass Polyester
Zinc Nylon
Molybdenum Epoxy
Tantalum PMMA
Titanium PVC
Tungsten PET
Cu/Be Alloy C172 ABS
Magnesium Alloy AZ31B
