Vibration measuring
Vibration measuring
When using a MV motor vertical mounted, shaft down, and wanting to use velocity transducer for continous vibration monitoring of the bearings,what is the best position to fix the sensor, i.e (H) Horizontal, (A) axial or (V) vertical
RE: Vibration measuring
For better control an axial sensor could be added.
