Panning in Microstation...
Is there a patch to make Microstation V8 pan like in AutoCAD, ie hold mouse button and drag the drawing around.
Please help the AutoCAD user forced into V8 and in extreme pain, torture, etc!!! At least for a while...
Thanks.
Thanks.
RE: Panning in Microstation...
I've been using AutoCAD for year and a half and now the Microstation for two years, so i am not exactly new to either. I feel the MStation is a more powerfull (especially in 3D) (but if you want a 3D there is Inventor) but with some bread and butter stuff the Acad wins hands down. Unfortunetly it's the bread and butter stuff that you use all the time while more fancy stuff is something you use only ocassionaly.
And after all this time i still miss the Acad one mouse button panning ability. I also miss the display of a full file path on top of my drawing. That alone is such an idiosyncrasy it is beyond belief. Every other program, be it a word processing, spreadheet or whatever always displays full file path.
This is turning into a bashing. Sorry did not mean to...
At the same token i miss the days of programming in DOS...
I feel like an dynosaur!
When you select the pan icon, a dialogue box title pan view should open with an option to turn on/off dynamic display. If you click that on, then your panning action will work like AutoCads.
Mike
