Textual dimensioning of holes
How can I make Catia to dimension holes & threads in textual form.  For example 2 x Ø1.25 Thru in the Catia V5 Drafting Module ?.  Thanks in  advance
RE: Textual dimensioning of holes
You cannot do it automatically.
You will have to turn the "manipulators" on. (Tools -> Options -> Mechanical Design -> Drafting -> Manipulators)
By doing this, when you click on the dimension, there will be 2 inverted red triangles that appear.  Picking them will allow you to add text.
Good luck.
Check out CATBlog!
