Unable To Save File
Unable To Save File
Unable To Save File
I have just finished a PSM sheetmatal file and now SE will not allow me to save it. I cannot save it to my network, which I am logged into. I cannot save it to my local C: drive. I cannot even save it to a compact flash drive card. The actual dialog box reads:
Cannot save the file. You may not have write-access for the file or directory.
Have I inadvertantly locked the file as read only somehow? It's a new PSM drawing, not generated from any other software. I have already made several other pieces and had no problems with them. Why this one?
RE: Unable To Save File
see thread:  problem with saving .dft files
dy
I found one additional solution to this problem:
[cite]
Most everyone has encountered the dreaded
"Cannot save file ...." error in a 3D Solid Edge environment.
Well, I've had tremendous success lately by switching the view format from Shaded
with Visible Edges to Visible and Hidden Edges, then selecting the Save icon.
From that point forward, I can save the file again using Shaded with Visible Edges.
Granted, this does nothing to help when the error occurs in Draft, but it's
a start.
Now, if only someone at UGS can explain why this trick works ....
[/cite]
dY
I tried that with no effect. However, I did convert the PSM file to a PAR file and it saved it no problem. It is strange. It really freaked out my Project Manager who also has MIS duties here. He thought that I had suddenly lost all access and rights to the server. Nope. Just SE and that particular file.
BTW, thanks for the tips donyoung.
