formula to calculate critical load of a free ends slender
Can any one tell what's the formula to find the critical load like for a slender which has both it's ends free and subject to axial compression.
Many thanks.
Many thanks.
Best regards,
ct
RE: formula to calculate critical load of a free ends slender
slender means high (L/rho)
perfectly straight means euler equation (pi^2*E*I)/(L^2)
1. rotation free (but guided) & translation fixed
2. rotation fixed & translation free (but guided)
3. rotation free & translation free (but guided)
Which one?
Best regards,
ct
maybe your slender rod is supported on axial springs (or something like), 'cause there has to be some connection to ground, no?
Best regards,
ct
F---> ------------- <---F
Then the rod won't behave statically, I mean it will JUMP,and after that no applied forces!
so this is not a buckling problem ( and can not be #3), because as soon as it starts to buckle it will jump out.
May I ask where is the application for this?
