Any one have this TI part: TLV3501AIDBVT
I'm in desperate need for 5 of this TI part: TLV3501AIDBVT. My prototype is being held up. It's an active part but has a terrible lead time from TI. I thought I would enquire with other Engineers because typically we only use half of what we order and put the spares in some filing cabinet. Any letters/numbers after the V would suffice as well. Thank you for any assistance offered.
RE: Any one have this TI part: TLV3501AIDBVT
If you search crosscomponents.com you will find that they show they have 155ea of this device. You may also want to try partminer.com
-elf
Thank you for the suggestions though.
Your right they leave off the bvt when searching, They got me. Is there any way of makeing the dual device (8pin) fit your in your prototype?
-elf
I'd also think about dead-bugging the IC. Just glue it (legs up) to the PCB and use little wires to route the signals to the pads.
