Flanges over 60"
Flanges over 60"
What flange do yoy use at sizes over 60"?
Related condition is as follows.
Service is process, not utility. The rating is CL 150.
Weld neck flange is required.
Maybe you use Taylor Forge Flange.
If you do use Taylor Forge Flange, where do you get dimensional data of the flange?
Bolt holes, DWG's...., etc.
RE: Flanges over 60"
I hope this helps.
