geotech in Canada
geotech in Canada
geotech in Canada
I recently completed my BSc Geological Engineering and presently working in UK as an assistant engineering, have been doing so for just over 2mnth on a £200M project which will last a year. Can some one kindly tell me what examinations is one required to take in other to register and to work as a geotechnical engineer in Canada. What type of softwares and level of CAD knowlege do I require
thanxs
RE: geotech in Canada
quocroch,
Working in Canada requires registration with the provincial or territorial association. For many jurisdictions, it may also require residency. Try visiting www.ccpe.ca (select 'English', 'Mobility', 'International Mobility' - they also have links to the provincial and territorial associations. You may wish to contact CCPE or the jurisdictional members directly in order to receive better advice than I can give at present.
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
