variable speed & load generator
I'm working on designing a device to keep tension on a moving line of wire. The tension (amount of force pulling back on the wire) needs to be able to be adjusted and the speed will vary. Right now we have dc motors w/ power to them creating the tension for us. I'd like to instead generate electricity to put back on the grid w/ them. Do you know of any generator systems that have the capability of changing both the shaft speed and load the load it takes? Thanks
RE: variable speed & load generator
