Unidentified Aluminium Nickel Bronze
I have been given a sample of what initially looked like a Aluminium Nickel bronze, chemical analysis revealed a composition I could not find a standard for and was wondering if anyone has heard of an alloy with a composition similar to this:
Cu 60
Ni 15
Al 12
Zn 9
Si 1.5
Fe 1.2
also traces of Cl, Mn, As, Ga, Sn, Se, Cr, Pb
The nickel content seemed a little high for most Aluminium Nickel bronzes.
The sample in question has failed in both an inter and transgranular brittle manner.
Any help or suggestions greatly appreciated
Gareth
Cu 60
Ni 15
Al 12
Zn 9
Si 1.5
Fe 1.2
Gareth
RE: Unidentified Aluminium Nickel Bronze
Never saw such a composition. Copper is low, and zinc & silicon are too high for an aluminum nickel bronze.
Is it wrought or cast material or p/m?
Tried Metals Reference Book, 3rd edn.
-- No wrought, cast or sintered p/m copper alloys near that comp.
Tried the 'Metal and Alloy Composition Search' at http://www.matweb.com/search/SearchComp.asp
--- No luck, even with broad composition ranges.
Tried Smithells, 7th Edn.
--- No copper base alloy (Sections 22.2 & 26.4).
Where did you obtain this piece of metal?
Is it related to any process or use in your facility?
Have you looked at the microstructure?
Probably contains brittle (Fe,Ni)Al, brittle silicide and Zn-rich interdendritic brassy phaase. Without the zinc, it seems like an experimental high-temp. Cu-based alloy.
Always a chance of some new alloy of which I am unaware, but more likly that someone forgot to sort some scrap metal.
The actual sample is a casting, it is the base plate of a blow moulding die that has fractured, there is also secondary cracking throughout.
The sample was given to me by a friend who I have not been able to contact recently so I am not certian about who made it either.
I think I will try and get it on the SEM and have a closer look.
Considering that the part came off a operational production line somewhere common sense would seem to indicated that its not an experimental alloy, more than likeley as you said a case of dodgy manufacturing, thats something I will be looking at anyway.
cheers
Ken
Sorry to ask a seemingly stupid question, but have you checked your analysis against a known material? (Just to rule out procedural error).
Yeah I have also checked the analysis with some known materials including a standard CuAl11Fe6Ni6 aluminium bronze, to rule that out.
In all honesty I had a feeling it might have just been a manufacturing mistake but without knnowing where it had come from thought it best to check.
cheers guys
CODE
http://www.fag.edu.br/professores/jane/T%201316/siderurgia.pdf
_______________________________________
Feeling frisky.........
www.tailofthedragon.com
seems very close to C99350
