compressor operation
dear sirs,
In our unit, we are using Refinery offgases as feedstock for hydrogen production.we running Centrifugal compressor which dicharges rfg gas @30 kg/cm2g to HDS section. my qusetion is
1. what is the effect of mol wt of feed on compressor performance.
2.what do we mean recycle trip of comp.what action should panel officer take immediately if it occurs.
I will be grateful if anyone takes to time to answer the above questions.
RE: compressor operation
For question 2 more information is needed from you.
Rocky Costello
www.rccostello.com
