Power Input Mode window
Can anyone tell me how to make the Power Input Mode window show up at the bottom of the screen?  Is there a toggle switch setting some place? Thank you for any help.
RE: Power Input Mode window
From the online documentation...
Quote (help docs):
Power input mode is a user-friendly productivity assistant allowing you to:
* enter numeric data more easily in editable fields and spinners (but cannot be used in combo lists); as such, it is intended as an alternative to typing values in dialog boxes (dialog boxes are however still available)
* enter commands directly (by typing the c: followed by the name of the command)
* entering selection queries using the query language available for the Edit->Search... command.
Power input is available in certain (but not all) application commands.
To activate power input mode, select the Tools->Options... command, click the General tab, and click the P2 option, then restart your session.
The power input field is located in the bottom right corner
of the status bar:
Check out CATBlog!
