Mapkey utility
Mapkey utility
Folks-
I've been having problems with mapkeys. I find that when I go to delete a mapkey it doesn't delete it from my config.pro. Has anyone else had troubles with mapkeys in WF 2.0?
Tunalover
RE: Mapkey utility
RE: Mapkey utility
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
RE: Mapkey utility
Do as dgallup suggests, use notepad or the config options editor to delete your mapkey, then save over your config.pro file.
RE: Mapkey utility
This way people can also create their own mapkey files that are easy to maintain.
notepad is a great editor and you can easily use my save all mapkey method with the notepad editor.
Michael
RE: Mapkey utility
It sounds like the user has to remember to load the file in with every session. Is there a way to invoke ADDITIONAL config files automatically using a setting in config.sup or config.pro? BTW, I learned (much to my dismay) that mapkey definitions in config.sup DON'T WORK.
Tunalover
RE: Mapkey utility
Believe there are three places that config.pro files can be placed that will be read automatically; load point, log on directory and start up directory.
I keep mapkeys in my standard config.pro (in log on directory). I don't let Pro/E add them, but save to a new file, inspect, edit (there's sometimes a lot of stuff that can be deleted and just get to the chase) then cut and paste into config.pro.
I think Help warns about putting mapkeys in config.sup?
RE: Mapkey utility
From firsthand experience, mapkeys don't work AT ALL in the config.sup.
Tunalover
