Dessicant Sizing
Dessicant Sizing
Dessicant Sizing
Folks-
Given a sealed electronics enclosure, if one knows the outside air temperature, pressure, and humidity profiles, is there a way to analytically predict how much moisture will condensate within?  The seal is a conventional linear O-ring in an O-ring gland of traditional design.  Also given are the inside surface area and volume.  I dug out my old thermo textbook but it contained no problems remotely close to this one!  Everywhere else I've looked, including a Google search turned up nothing.  TIA for your help!
Tunalover
RE: Dessicant Sizing
Oddly, I'm working on a similar problem.  However, your question seems to be different than the ones I would ask.
> What temperature range do you want to have non-condensation?
> This establishes the dewpoint, which dictates the amount of water allowable at room temp
> Which determines the RH at RT
> Which determines the steady-state desiccant demand
> What is your max temp and how much leakage, both outflow and inflow
> Which determines the amount of potential moisture introduced into the structure
> Which determines the amount of moisture to be removed at any given time
TTFN
IRStuff-
I'm trying to determine the amount of dessicant to use in the enclosure and how long it will last until requiring recharge.  I know the time history of outside RH, temperature, and altitude.  I just need to know how much condensate will form inside the enclosure.  Do you know of any papers on the subject where someone actually comes up with NUMBERS?
Tunalover
I'm kind've with IRStuff on this one.  A simple Psych chart will tell you everything you need about the air-water vapor mixture properties.  It will even assist with modeling the process.  However, you still need to estimate/measure the factors that he points out.
Condensation occurs when heated air, containing a higher moisture level, is cooled beyond the dewpoint temperature of the air-water vapor mixture.  Now, that may seem like stating the obvious, but the rest is up to you.
Out of IRStuff's list, I would count airflow into and out of the enclosure, and heat transfer through the enclosure's surface as most important - and totally dictated by your specific situation, your estimates, and your measurements.
How sealed is sealed?
If you can safely assume that there is no air exchange with the outside then the problem is relatively straight-forward.
If there is air exchange things get more complicated.
