variable frequency mechanical oscillator
I'm trying to figure out a way I can make a mechanical oscillator, (I guess an engine where the shaft only moves up and down), where I can change the frequency of motion by small increments. Doesn't need to be very big, pretty small actually. Any suggestions on the best way to go about doing this? I was thinking maybe an air or steam powered piston engine would work.
Davido Hyer
Davido Hyer
RE: variable frequency mechanical oscillator
Timelord
http://www.rexresearch.com/teslamos/514169.gif
I believe the frequency of operation can be varied by changing the weight that you can add on top of the shaft. This engine is steam powered. Any ideas on how to reproduce this kind of engine electronically?
Davido hyer
Voice Coil.
Rack and pinion driven by stepper or servo motor.
