Rebuild Error
Rebuild Error
Rebuild Error
I try to add a library component (in this case 5/16-18 x .75 SHCS) to an assembly.  If I try to add a different length or dia SHCS I get the following error.
This is a problem so far only with the UNF and UNC versions of SHCS and button heads.  Set screws and hex heads have caused me no issue.
"Rebuild of Failed"  or  "Rebuild of (pathed file name of hardware file) failed.
I do not see the same error if I move to another computer.
BTW, I am still running Inv. 8.1.  I am using the default library server and have the save location set to "Parent Assy"  Can anyone help?
