Conduit Seal (Chico) Removal
A few days ago I posted a question about testing conduit seals (http://www.eng-tips.com/viewthread.cfm?qid=141712).  I have a separate question about conduit seals resulting from the same project referenced in that thread:
Is there a recommended method for removing conduit seals without damaging the conductors and introducing something into the conduit that could cause problems later?
I understand that chipping out the seals works but usually damages the insulation or conductors and almost always leads to repulling the wires.
I've heard about using vinegar (which I also found mentioned at http://www.elec-toolbox.com/tricks/chico.htm).  This method could be slow and still require chipping, according to one electrician.
Finally, I've been told that Chico (not including SpeedSeal) is essentially plaster-of-Paris, though the MSDS (http://www.crouse-hinds.com/crousehinds/resources/msds/ms_chico_sealing.cfm) says it is only about one-third p-o-P.  A Google search resulted in a link to a site that discussed using "a dilute potassium acetate solution" to remove plaster from molds (http://www.plastermaster.com/usg/plaster201.htm) but I couldn't determine whether this would work with Chico.
I couldn't find anything in the literature on CCH's web site about seal removal.  My question applies to conventional seals; it would appear to be essentially impossible to remove an epoxy SpeedSeal based on CCH's video and support documentation.
RE: Conduit Seal (Chico) Removal
Cut the wire, remove the fitting.  Throw the fitting away and replace.  Your tripping over dollars to pick up a dime.
You can dissolve epoxy using something like dichloromethane, although it takes a while. The process has the downside that the chemical is carcinogenic and is one of the most aggressive organic solvents available, so any polymer-based material is in for a hard time. BJC is right - scrap the fittings and replace them.
  Start each day with a smile. Get it over with.
When I worked in the semiconductor industry, we had a wonderful machine for dissolving epoxy packages.
It was called a JetEtch.
It used boiling concentrated sulphuric acid...
Just a thought...
Scrap it & start again sounds reasonable to me...
