_AMNOTE (LINE WEIGHT SETTING)
Does anyone out there know how to change the (_amnote)
line weight setting default to .25mm.
Mine keeps reverting back to .05mm whenever I use the "leader note" from the "annotate" pull down menue.
This causes the "note" print outs to be nearly invisible.
The default layer for this function is (AM_5) & I have that layer line weight set to .25mm as the default.
