Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I think this forum rocks it has saved my bacon many many times..."
Geography
Surface finish for steel sliding on Teflon
Revelation19 (Mechanical)
9 Dec 05 9:11
I am interested in using Teflon (or other polymer) to act as a slide on the inner surface of a steel cylinder. The cylinder has an ID of 15 inches (0.38 m). It needs to slide slong its axis a length of 1.75 inches (44.5 mm). It is used in a test rig and will move only occasionally (once a month or less), however it needs to be able to move the full distance in about 1 second. It also has to act as a marginal pressure seal, though this is a secondary function. I envision using a strip of Teflon bonded into a groove cut into the inner cylinider. (The Teflon strip I can purchase has an etched side for bonding.)
My question is: Is there some particular (or minimum) surface finish I need to use on the inside of the steel cylinder?
rnd2 (Materials)
9 Dec 05 10:15
Minimum is a fine evenly ground finish. There is no need to polish the inside sliding surface of the steel cylinder.
plastx (Materials)
9 Dec 05 12:28
I agree that a fine even finish should work. Some PTFE bearing manufacturers give guidelines like 8 to 16 µ inch Ra if you need to spec it out. The following link is for linear bearing material that calls out this finish guideline:
http://www.rulon-meldin.com/Media/Documents/S0000000000000001016/epprulon142.pdf
Check with your supplier to see if they have a recommendation.
Mike
Pressed (Mechanical)
9 Dec 05 19:55
CODE
http://www.nhbb.com/engineering/astro/liners.cfm
Down towards the end of the document.
_______________________________________
Feeling frisky.........
www.tailofthedragon.com
rnd2 (Materials)
10 Dec 05 4:28
Do you mean this?
extract from website: "......Surface Finish and Hardness
Surface finish and hardness for the surfaces running against a TEFLON® liner are important for maximum liner life, whether on the shaft, ball, or other running surface.
For maximum life, NHBB recommends a finish of 8 Ra maximum, achieved by lapping, buffing, or honing after grinding. Anything higher than 8 Ra will reduce life.
Hardness should be Rc50 minimum. As hardness drops below Rc50, the mating surface begins to wear............" end of website extract.
From my direct experience with plain (simple) bearings, whereby the shaft is metal; either carbon steel or stainless steel, THAT SLIDES (not rolls) against a bearing surface, free of extraneous abrasive particles, and made from PTFE, Phenolic, UHMWPE, Nylon, etc. I have never observed an obvious benefit of having a polished surface. For the same application, I have never observed an obvious benefit of the shaft having a special hardened surface either.
10 Dec 05 17:06
CODE
http://www.polylube.com/pdfs/Fiber_Series.pdf
http://www.sdp-si.com/D780/PDF/D780BRG012.PDF
www.parker.com/packing/cat/english/5315_FlexiSeal.pdf   page 8
http://www.nhbb.com/assets/pdfs/catalog/AstroEng.pdf
http://mdmetric.com/or/applicgb.htm
If you have evidence to the contrary, all I can say is that the experts have differences in opinions.  Nothing new to that.
damienk (Materials)
23 Dec 05 9:42
from my knowledge, sliding between polymer aand metal can lead to a so cladde stick slip process which means that your "realtive sliding" is not so good. And what about wear of PTFE ?
23 Dec 05 11:40
We have only in passing considered wear of the Teflon. I have raised this question (I assume we will get wear) but as we are building a prototype test rig, we are glossing over these details for now. I, for one, have added that to the observation data to be collected at the completion of the testing. I am also thinking of having the leading and trailing edges of the Teflon strip chamfered a bit to ease entry and assembly.
For now, the consensus in our design group is going with a mere 64 finish on the ID of the cylinder.....
Close Box
Join Eng-Tips® Today!
Join Us             Close
