corrosion of carbon steel flange
Due to an error in wall thickness calculations we have two pipelines connected together with a difference of 16mm. this crates an 8mm raised lip on one side.
The fluid is a warm  brine produced water highly corrosive fluid with a reasonable amount of dissolved iron, the system is designed to avoid ingrss of oxygen.
My question is: will this lip create turbulance and/or induce a bacterial growth area and hence become a corrosion mechanism.
RE: corrosion of carbon steel flange
It depends on flow conditions. What is the design process stream velocity thru this pipe?
It could become a site of enhanced corrosion (rather than a 'mechanism').  Can you not match bore a little bit to give a transition?
Steve Jones
http://www.pdo.co.om/pdo/
The rating of the system is 1500 ILB
I may the contractor ask to chamfer the flanges to help the transition
I would expect some accelerated erroson/corrosion at the site.  Anything that will reduce the turbulance will help.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
From a strength perspective, I doubt very much that the flange will be the weak link.  You can probably taper the edge of the one flange quite a bit, with the limiting factor being cost.
As others have stated - reducing turbulance will only help.
