Gear Pump Sizing
Gear Pump Sizing
When sizing a gear pump, does discharge head play a role in sizing the pump? I looked and saw that the flow rate depends on the RPM and the horsepower of the motor. It also states this at a different pressure (ex. 0 psi and 100 psi). Is this pressure the discharge head? If not, what does this pressure correlate to?
First time sizing a gear pump. Thanks.
RE: Gear Pump Sizing
Regards checman
Regards checman
