Engineer Title
Engineer Title
In Wisconsin they have licensed "designers" and licensed "engineers". Designers being a 2 year graduate and engineers being 4 or more years with different test requirements for licensure.
Is it legal for a person to use the title "Project Engineer" on their business card when they are only a lisenced "designer"? This person is not advertising themselves as a "PE" although he often refers to himself as an engineer. "Project Engineer" may be only the title the company gave them.
RE: Engineer Title
TTFN
RE: Engineer Title
In Wisconsin a licensed designer is not a PE, although in their specific limited fields do have considerable authority. As far as a job title goes however just about anyone can be called an engineer in Wisconsin. You don't need a 4 year degree, a 2 year degree, or even a high school diploma. It's up to the companies here to give whatever job title they want.
If you need to know more try the following link, but I'm not sure exactly where. Comm 61 thru 65 concerns the building code.
http://w
-Mike
RE: Engineer Title
Step outside of that company, however, and try hiring yourself out as an engineer: You may go to jail. The PE requirements are similar to those of other states, with degree, the national EIT & PE exams. (Maybe a little easier: Looks like an accredited 4 year degree, 8 years experience & 5 appraisal letters might do it.) See
http://drl.wi.gov/prof/engi/form.htm
RE: Engineer Title
You are right, hiring yourself out as an engineer is a whole different thing. But job titles and business cards can be just about anything, or least it was in the past. Maybe it's getting better now.
-Mike
RE: Engineer Title
The simplest and most direct way to find out is to call you state engineering board office and simply inquire. They are all usually very eager to assist in clarifying the state's laws on engineering practices.
RE: Engineer Title
In every jurisdiction in Canada only professional engineers can call themselves engineer in any way shape or form with three exceptions. Railway engineers are train drivers, Power engineers operate boilers and military engineers are sappers. In each of these cases they can only use the term engineer along with the applicable modifier.
Microsoft Certified Systems Engineer is illegal in Canada unless the individual is also a Professional engineer with one of the Canadian associations.
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
RE: Engineer Title
Just curious. How about the business title "Engineering Technician"?
RE: Engineer Title
The UK has a licensed Engineering Technician profession:
ht
RE: Engineer Title
I’m not 100% on this but as long as you do not use the certified or registered part or the associated initials CST or RET then you can call yourself an engineering technician.
I believe that it’s more a copyright issue than a right to title issue.
RE: Engineer Title
I'm a firm believer that the term "Engineer" implies to the public that the person has special expertise in a technical area and that the person can be relied upon for appropriate ENGINEERING based solutions to issues or problems. For non-engineers to use the term is misleading to the public and, in my not-so-humble opinion, an infringement on the rights of properly qualified and licensed engineers. Most states do not put enough "teeth" into their laws to enforce this.... a shame for engineers.
RE: Engineer Title
Honestly though, in the biomedical field I don't think any company cares one eay or the other about the PE, and it's my understanding that most Aero. or M.E. firms are the same.
I think this topic has been done to death, but I see the P.E. as being a mostly Civil thing.
RE: Engineer Title
John
RE: Engineer Title
So if your company consists of consultants hired out to the public then no engineer on your card, if they are not, then put whatever you want on the card.
RE: Engineer Title
RE: Engineer Title
The personal licenses are required for anyone doing engineering work of any description but the corporate license, often called permits to consult, authorizations to practice, or other term are required for provision of engineering services to the public.
For this license the public is considered to be any client to whom we are selling engineering services to and not engineering services coupled with some other physical good.
Thus an engineering firm partnered with a construction firm for q design build project would require a license to sell the engineering services to the construction firm but a design build firm employing both engineers and construction workers would not require a corporate license for the engineering part since the final product is not engineering services but a completed project.
Personal licenses would however be required by all the engineers in both cases.
RE: Engineer Title
"In order to safeguard life, health, property, and public welfare, no person shall practice civil, electrical, or mechanical engineering unless appropriately registered..."
This is the crux of what the PE laws provide. Even here, there are some technical loopholes, since most commercial products that are engineered in California are not generally subject to PE control, even though it might be argued that your stereo or computer could have an adverse effect on your life, health or property.
TTFN
