Flange gaskets for fire protection
Would somebody please tell me what kind of gaskets are required for flanges on fire water protection systems.
Tipe of flanges: carbon steel, cast iron, flat face and raised face ASME/ANSI class 125/150 flanges. Diam: 2 1/2"-8"
Pressure up to 150 psi.
Water: river or tap water.
Are there gaskets FM approved or UL listed for fire protection?.
Can somebody mention specific manufacturers or materials for such gaskets.
RE: Flange gaskets for fire protection
NFPA 24 has no requirements for listed gaskets for private fire protection water mains. Section 6.1 requires that the valves be listed and I would assume that the gaskets that are supplied with the valve are evaluated as part of testing laboratory.
I can research this in greater detail in the morning and see what I can findout.
I will have to contract one of the sprinkler distributers and ask them what brand they stock.
I also did a quick search of NFPA 13 and found the following reference "AWWA C111, Rubber Gasket Joints for Ductile Iron Pressure Pipe and Fittings, 2000." But that only applied to underground piping.
