Can't always select hatch
I am writing a program that draws/builds walls with rectangular polylines. The wall perimeter is defined by a closed group of lines. My program creates solid hatch around the group of closed lines in order to more easily tell if an area is outside of the group of lines. The problem is when I select an area it may not see that there is hatch in that area. Is there a minimum area that needs to be selected to guarantee that it picks up all entities? Could I be zoomed out too far? Is there an inherent problem selecting hatch? Any ideas?
RE: Can't always select hatch
This is how I select hatch's.
Chris
Systems Analyst
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
John
I'm thinking that I may try to draw lines within the area where I was using hatch because I can select the lines without any problem.
