firm foam
firm foam
Hi All,
I am not sure where to post this question, so I hope someone will direct me to the appropriate forum.
I am looking for a foam material to put in an enclosure approximately 1" - 1.38" deep to hold dummy under water connectors while not in use. The foam has to be rigid/firm to grip on the connector so not to allow the connectors to fall out upside down. The foam material should be tear and moisture resistant. The next question is how would cut this foam out to the shape of the connectors with finger grooves to allow access to get at the connectors.
Thanks for any advise you can provide
Tofflemire
Tofflemire
RE: firm foam
http://www.eng-tips.com/threadforum.cfm?lev3=57
RE: firm foam
Cut with hot wire.
RE: firm foam
Cheers
Greg Locock
RE: firm foam
RE: firm foam
RE: firm foam
