Need Help. Delta Flow Divider 50/50
I am really new to fluid power.  I have a delta 50/50 flow divider (HPR23).  It has 2 inlet ports.  One on each end.  I was expecting only 1 inlet and 2 outlets.  Do I need to Tee the inlets togehter, or can I just hook up one of them.
TIA.
RE: Need Help. Delta Flow Divider 50/50
Ok, the answer I found was that I could tee the line from my valve and go into both inlets or I could plug one, and use only one inlet port.
