Basic BOM and balloon questions
I have a couple BOM and balloon questions.
I have one large assembly that has about 75 parts and two sub assemblies. When I autoballoon it puts balloons on all the items in my subassemblies. It would be too large and confusing assembly to have everything exploded and ballooned on one sheet. So my original thought was to have 3 separate assembly drawing pages: The all inclusive one with the two subassemblies not exploded, then an assembly drawing for each subassembly and one large BOM on a separate page
1. Is there a way to have the autoballoon balloon the subassembly as one part rather than 25 individual parts?
2. How do I make the two sub-assembly drawing pages not start at 1 (so that I can have one common BOM)?
RE: Basic BOM and balloon questions
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP1.0 on WinXP SP2
1. Insert -> Tables -> Bill of Materials -> Top Level Only.
2. As long as the part numbers are on the top level BOM
and the same part numbers are on the subassembly sheets thats all that matters. The item numbers are meaningless.
You might also want to consider using indented assembly
instead of top level only.
1. You could go to the Sub-Assembly and under the
Configuration Manager check on the "Don't show child
components in the BOM when used as sub-assembly" option
it is located about 3/4 of the way down the CM, this
will show the Sub-Assembly as one part in the BOM.
Hope this helps
Cheers,
Ralph Wright, CSWP
SolidWorks 2005, SP5.0
P4, 2.53Ghz
1.5 Gb RAM
ATI Fire GL8800 Card
Windows 2000 Pro
