How to Move DXF File imported into WildFire?
Hi you all.
I imported a DXF file into ".prt" wildfire but it was positioned according to its original WCS on to .prt's WCS.
So I don't like that, because the dxf lines are far away of WCS.
To fix it, I want to move the whole lines taking from whatever point of the imported lines to .prt WCS.
It is possible? cause I'm trying but I can't get success.
RE: How to Move DXF File imported into WildFire?
Then when you import the file, choose your new CSYS as a reference in your part.
Then reorder the new CSYS to before the import feature.
Then edit the references of the import feature, replacing the default csys with the new one.
I can't try it now, so I can't guarantee it will work.
Hope it does.
Good luck
