Conductor Sizing and Voltage Drop
I have a 480 V,25 hp motor I am wanting to select the right condutors for. The FLC of the motor is 34 amps and the distance between motor and motor starter is 730 feet. When running a voltage drop calculation to determine the proper size of conductors , should I be using 34 amps as the ampacity of the circuit or should it be 34 amps times 1.25?
RE: Conductor Sizing and Voltage Drop
