AUTOCAD 2002 INSERTING CUT & FILL DATA ON TO CROSSSECTION SHEETS
Does anyone know of a way to take the generated earthwork information you get and insert it into cross section sheets using AutoCad 2002? I'm thinking a macro program will do the trick , but don't know to do it. Any help would be appreciated.
RE: AUTOCAD 2002 INSERTING CUT & FILL DATA ON TO CROSSSECTION SHEETS
