Section VIII Safety Valve Blowdown
In ASME Section I there are requirements for PSV blowdowns (it must close no lower than 96% of the set pressure and the minimum blowdown must be not less than 2% of the set pressure, PG-72.1).
Are there such requirements for ASME Section VIII PSV's? What are the minimum and maximum PSV blowdowns for PSV's protecting pressure vessels?
RE: Section VIII Safety Valve Blowdown
I'm looking for blowdown pressures. In ASME Section I, a PSV with a set pressure of 100 psig must close between 96 and 98 psig. It can't remain open down to 90 psig for example.
For a PSV with a set pressure of 100 psig protecting an ASME Section VIII pressure vessel (not a steam generator), what would be the required closing pressure or pressure range?
Just as additional info, here's some references to what you will find in ASME Sec VIII.
From the Anderson Greenwood website...
http://www.andersongreenwood.com/literature.asp
Anderson Greenwood
Technical Seminar Manual
http://www
Includes a one page, side by side comparison of Sec VIII and Sec I valve requirements.
Crosby
Pressure Relief Valve Engineering Handbook
http
Includes excerpts from ASME Sec VIII. In particular, look at UG-131(c)(3)(a), UG-136(c)(3)(b) and Appendix M.
"Pressure Differential Between Safety or Safety relief Valve Setting and Boiler or Pressure Vessel Operating Pressure"
F-5000 Pressure Vessels
Only general guidelines are provided. After a self-actuated release of pressure, the valve must be capable of re-closing above normal operating pressure. Example given;
if a valve is set at 100 psi with a 7% blowdown, it will close at 93 psi. The operating pressure must be below 93 psi to prevent leakage or flow in service.....
For set pressure up to 70 psi, the recommended pressure differential is 5 ksi
For set pressures between 70 and 1000 psi, the recommended pressure differential is 10% of set pressure.
For set pressures above 1000 psi, the recommended pressure differential is 7% of set pressure...
After a self-acuated release of pressure, the valve must be capable of reclosing above the normal operating pressure. For example: Valve set @100# with 7%blowdown, it will close at 93#, The operating pressure must be maintained below 93#in order to prevent leakage or flow from a partially open valve. Taken from NBIC 2001 Edd.App F Part IV
Thanks for the replies. Just wanted to make sure it wasn't saying something different than what the other references indicate.
The set pressure tolerances for pressure relief valves per UG-126 of ASME Section VIII Div.1 are , plus or minus, shall not exceed 2psi for pressure up to 70 psi and 3% for pressure above 70 psi.
You are describing the set pressure tolerances allowed by ASME Section VIII. I was looking for the blowdown (valve closing) tolerances.
