Unable to restart Ansys
After loading an input file which crashed Ansys, I am unable to restart Ansys. The output window shows only the following message" Unable to open file file.lock for WRITE Check Directory and File Permissions"
Following display of this message, the output window closes. I located file.lock; file properties show 0 bytes in length.
I created a new file.lock and tried agin with the same results. The permissions given to modify the file are set to full.
Does anybody in the Forum have a suggestion?
Art
Art
RE: Unable to restart Ansys
Thanks for the suggestion. Am not sure if I did this correctly by creating an evironment variable called ANSYS_LOCK and setting the value to 0.
When I started Ansys after adding that, I now had a similar error where the file file.err could not be opened for write and the program then crashed.
Any more suggestions?
Art
ok - is the file deleted? Now...
Afterwards, create the variable - the value must be OFF, not 0.
I changed the variable from zero to OFF, rebooted the computer, and now have a similar error where "file file.err cannot be opened for write" and then, program crashes.
File.lock is gone, cannot be found with search.
Suggestions?
Art
More suggestions?
Art
Art
Another thing - have you checked out TFM for any advice it may give on your problem?
"C:\Program Files\Ansys Inc\v80\CommonFiles\TCL\bin\intel\wish.exe" "C:\Program Files\Ansys Inc\v80\CommonFiles\Launcher\LauncherMain.itcl" -runae
I could not figure out how to start the program from this directory.
Where is the ANSYS product launcher?
TFM??
Art
Where is this installation? Is it a university or a company or what? These are all pretty basic questions that either your university ANSYS contcat or your company's ASD (ANSYS support distributor) should be able to answer. Did you install the program yourself?
Please go and read the manual and/or talk to someone at your scholl/work who knows what's going on.
