ADA Compliance -- Sec.36.403 Alterations: Path of travel
I work for the DOT in Baltimore, MD.
I have a question regarding the need for ADA compliance based upon the following situation:
An existing roadway is to be streetscaped and resurfaced.  Building Faces extend to the ROW.  The existing cross-slope on one of the sidewalks is at least 8% from the face of building to curb.  In order to obtain a 2% cross-slope on the sidewalk, we will have to reconstruct the roadway.
1)       Do we need to make the cross-slope 2% to be compliant?
2)       Can we apply for an ADA Exception based on Disproportionality?  The cost to reconstruct exceeds 20% of the cost to resurface.
RE: ADA Compliance -- Sec.36.403 Alterations: Path of travel
How wide are the sidewalks? If they are 8' wide, you could provide a 5' accessible route, and a steeper 3' buffer.
The Access Board provides technical assistance. Why not ask them directly?
     "...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail."
              Wm. Phelps Eno, ca. 1928
