STANDARD HEADS
STANDARD HEADS
CAN WE USE STANDARD F&D HEAD AS A TOP OF ASME TANK WITH NO INTERNAL PRESSURE - DESIGNED FOR FULL VACUUM ONLY?
UG-32(j) SECTION VIII DIV I PROVIDES LIMITATION TO KNUCKLE RADIUS NO LESS THAN 6% OF OUTSIDE DIA, BUT UG-33 DOES NOT MENTION ABOUT IT. WE HAVE ALL REQUIRED TEST REPORTS ATC.FOR THIS HEAD.
RE: STANDARD HEADS
Steve Braune
Tank Industry Consultants
www.tankindustry.com
