hide/show function of singular parts
Basically, I was wondering if this is a bug (probably not),
and, if not what can I do about it?
Assemblies created in 2006 are OK,
Assemblies created in 2005 then opened in 2006 - 'HIDE' does not work (SHOW does)
[HIDE works on sub-ass'ys]
RE: hide/show function of singular parts
2) If you uninstalled 2005 first, try doing a repair on your 2006 install, then see if you have the same issue.
Mechanical Engineer
PDMAdmin - that didn't work either.
When you right click on the solid body in the feature manager tree go down to customize menu and see if you have the option to select the HIDE box.
Mechanical Engineer
I can RT-click in the feature manager tree, and 'show' is an option, but no 'hide.' I go to the VIEW menu, and 'hide all types' is all I see.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
(By the way, I've figured out an unacceptable solution, and that is, if I click on the part in the feature manager tree, then go up to 'EDIT' pull-down menu, I can hide the part, but why won't it hide by right clicking, and selecting Hide Part.
Also when you did the new install did you clean out the registry?
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
So that means if the body is hidden you will only see the "Show" option. If that part is "Shown" then you will only see "Hide".
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
But after a little monkeying around, I've determined that the problem may be specific to the file/corrupt (that's a catch-all for those IT experts out there).
So is it my version of 2006? I don't think so, however it may be that a part created in 2005 - has these hide/show problems. Is that a proper suggestion?
What's you're catch-all phrase when you can't figure something out? I'm curious
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
I have files moved into SW06 from SW05 & SW04. I have not seen this with any of my files.
I tested this on my part and I don't see Hide if the part is hidden.
How can you be completely sure that the install went flawless?
You can't be, even if you took all the necessary precautions. If you have not learned by now, Computers have a mind of their own and will work the way they want to work. If you cannot see a particular menu, then in 95% of all cases this is an install issue or a corrupt registry file within SW Reg setting.
If you disagree with me and all the above, then contact your VAR and have them diagnose the issue. Because I don't think any of us can help you.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
ColeM CSWP
