looking for ASTM A53/A53M and A135
I am looking for the codes on the above things
If any body can help out it would be great
RE: looking for ASTM A53/A53M and A135
You can order them at astm.org.  Should be about $20 each.
Hg
Eng-Tips policies:  FAQ731-376
These are Copyright 2005 ASTM International.
ASTM A53/A53M-05 Standard Specification for Pipe, Steel, Black and Hot-Dipped, Zinc-Coated, Welded and Seamless
is 22 pages, $44.  Pretty cheap for a standard @ $2/page. Read the summary at
http://www.astm.org/cgi-bin/SoftCart.exe/DATABASE.CART/REDLINE_PAGES/A53A53M.htm?L+mystore+rhxt6857
ASTM A135-05 Standard Specification for Electric-Resistance-Welded Steel Pipe is relatively expensive, only 9 pages for $33.
Note that both are 2005 revisions.
If you are going to be dealing with a lot more ASTM Stds that pertain to steel in future, you might as well purchase the ASTM Book of Standards Volume 01.01: Iron and Steel Products. It contains 120 standards and is slighty over $200.
Or join ASTM for $85 and get the book free.
These documents are the basis for contracts.  Don't be foolish and reference a spec that you haven't read.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
