problem with working directory
I have installed proe Wildfire on computer at work ... it wont let me alocate the network as working directory ... it using the desktop as its working directory and all other files must be then saved again on to the network help please...?/
RE: problem with working directory
Do you have write access to that network directory?
My advice: don't do this... it will slow down your work session significantly when there is network traffic.
Map the network drive to your machine and then use that as your working directory.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
