How to create a video to display a model to clients
Hi
Was wondering how do you create a video or movie of a part  on its own and maybe a system of parts working.. its probably hard and time consuming but anyhow.
RE: How to create a video to display a model to clients
There are many ways, depending on what you want to acheive. If you have the Animation module, you can do it there. You can add motion to parts, explode the assembly and rotate among others. Then save it as a video playback file.
Or, if you have a screen capture software, use the video portion of it and have it record all your assembly manipulations, not as slick, though.
Steve
http://www.sprdesign.com
http://www.3dlogix.com
Heckler posted a link to a great guide on design animation a couple of posts back.
http://www.mooload.com/file.php?file=files/1133821279/Design+Animation+Topic+Collection.pdf
It is for 2001 but most of it is still valid for WF and WF2.
For a single part, I usually make an axis for it to rotate around, drop it into a dummy assembly, add a servo motor to have it rotate 90 degrees per second, and record an animation for 4 seconds. I usually record sequential images to a different directory and make an animated GIF out of the frames (this lets me create transparent backgrounds for use in powerpoints, websites, etc).
Does anyone know how to control the speed of the Animation Capture so that the mpeg can be played at a slower speed. Mine always seem to run fast and I cannot find a way before Capture that affects the mpeg playback in a media player.
Cadmanpro
You need to play around with your frame rate.
When you record your MPEG, you have three options: 25, 30 and 50 Frames per second (FPS).
So if you are recording your MPEG at 25 FPS, you need to make sure that the animation or motion analysis is also recorded at 25 FPS to ensure that the animation is running on a 1:1 time scale.
If you want to slow it down, you can record your motion analysis with a higher frame rate. It will still cut to the MPEG at 25 FPS, except it will seem to be moving slower, since the steps between each frame are now smaller.
Hope it helps!
