Automatic or implied relations?
I have a problem with several models I have drawn. I creates the sketch with Automatic relations on and it has define the center of an arc coincident with a line that it shouldn't be. The sketches I did with Automatic relations turned off do not have this problem. I need to define the arc by three points along the arc and not the center. I have deleted all relations shown when I select this arc but the center point stays coincident to the line. Any suggestions and what I can look for?
RE: Automatic or implied relations?
Timelord
1) Right click on the arc center / midpoint and choose select other. This should let you pick the arc center to display / modify its relations. I think this might have been a new feature in one of the last two releases, so depending on your version, it might not be available.
2) While editing the sketch you can toggle on and off display of relations. The default toolbars have an icon for this. When relations are displayed they appear as little icons. A relation can then be selected by clicking on its icon.
Eric
Once in a while I run into the same problem with relations and overlapping sketch entities. The simplest solution is to click on the Display/Delete Relations icon (it looks like a perpendicular symbol with a pair of eyeglasses on it; or go to Tools->Relations->Display/Delete) and then select All In This Sketch. A list of all relations in the sketch will appear in the properties dialog box. Find the offending relation in the list and delete it. This handy tool also works well for finding those dangling and over defined relations in complex sketches.
Matt
SW06 sp2
Dual 3GB Xeon, 3.5GB RAM
ATI FireGL Z1
