What type of Back Flow Preventer is needed for a low pressure fountain
Not sure whether to use a pressure vacuum breaker or a reduced pressure assembly. I have a max pressure of 80psi and a 1" cold water pipe.
RE: What type of Back Flow Preventer is needed for a low pressure fountain
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
Richard A. Cornelius, P.E.
WWW.amlinereast.com
If no potential for back flow then a pressure vacuum breaker will work. Use one similar to what is used for landscape irrigation systems.
