Update model with design table still open?
I have a DT opened in a new window. Is there a way to force an update to the part model after making changes to the design table without closing the DT first?
Tom
RE: Update model with design table still open?
tmalinski
Yes there is but it requires API programming
Regg
That's a whole step further then to just use SW, and unless you are a code person or advanced in SW I suggest you consider having someone help you with that process.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Thanks Scott, for now I don't think this is an issue worth diving into, its just a minor inconvienence. I open the DT in another windo so I can utilize other excel functions as I create stuff. But then accessing it in SW works just fine
