1hp 120v explosion proof single-phase motor
I want to buy a 1hp 120v explosion proof single-phase motor, who is the good manufacturer? Anybody could recomment?
RE: 1hp 120v explosion proof single-phase motor
www.baldor.com
I found 10, 1 HP 1 Phase, XPFC (Explosion Proof Fan Cooled) motors.
Reliance has many years of experience manufacturing explosion proof motors. The line S2000XP has all type of motors in your required range even for Class I&II, Groups C,D,E,F&G and with inverter duty features see:
ht
Personally I've found that most engineers, specifiers, and tech's feel that U.S. Motors, Baldor, and Leeson produce some of the highest quality motors that are widely available here in the U.S. You should really speak with a major motor sales and repair shop in your own area. If you don't know who that might be, ask electricians or electrical supply houses.
What is the reason you need an explosion proof motor? Will you be pumping flammable liquids or operating in an environment with explosive gases? We used to use these for circulating alcohol ink and have converted to water base ink but prefer them now due to the tight seal they offer, It makes clean up possible with no damage to motor from moisture contamination.
Sincerely, Chuck
It is difficult for me really to look for a 1 phase, 127v, XP motor. So far I've found Baldor motor has a 115v/50hz/1HP/1450rpm motor with 15% voltage variation. But is there other alternative choice? Anybody could help, thx!
These are some of the pumps we use which most electric motors on these are Graymills and work well for us.
http://www.powerwise.com/centrifugal.html
Chuck
