condensor Coil/ compressor selection spreadsheet
Do anyone know where I can find a coil / compressor selection spreadsheet on the Net?
RE: condensor Coil/ compressor selection spreadsheet
There are too many compressors and condensers to even beging to try and put together a spread sheet.  All you have to do is to cross plot the compressor THR (total heat of rejection) against the condenser capacity.  Or you can set up an Excel spread sheet to do the plot for you.  Takes all of 5 minutes or less to do it on paper.
Ken
TXiceman
www.rae-corp.com
