Steam turbine exhaust enthalpy determination
Dears,
The steam turbine + generator is designed for 6 MW power generation. Thsi is an extraction-condensing type turbine. Inlet steam pressure 44 bar, inlet steam flow is about 25 tons/hour. After first stage, pressure is 15 bar and temperature is 370 Deg.C. Condensing pressure is 0.06 bar absolute and temperature is 45 deg.C.
Due to the possibility of wet steam at the first stage extraction, I am finding it difficult to find out the enthalpy. I refered to ASME PTC on Steam turbines and finding it extremely difficult to understand the iterative procedure.
Assuming 0% wetness in exhaust steam, I got the enthalpy of steam based on temperature and pressure and then I got 1st stage efficiency of 84.8% and condensing stage efficiency of 60%.
My question is: How important is the need of an iterative calculation suggested by ASME? Will the error be significant?
Dinesh
Dinesh
RE: Steam turbine exhaust enthalpy determination
Modern blades should have stage efficiencies on the order of 90+ %, not including throttling losses , pressure losses thru extraction nozzles ( at the pressure measuring point if extraction flows are in service), and exhaust losses. I think you will need to make at least one more iteration just to see the order of magnitude of the error.
Given the outlet conditions, looks like that is superheated as well.
The thermal efficiency:
((Extracted Enery at 15bar& 370C)+ (Electrical Energy at Generator Terminal)) / (Input Energy at 44bar&??C)
norzul
Thank u all for your replies.
