Strainer for gas service
Friends & experts, pls help: 1" CS (150# class - DP: 1900kPa) instrument gas strainer need to be replaced, what would be the best option of strainers (preferably flange-flange type) available? Pls advise on any website to gather more info on product models. Whether 'Y'-type strainers could be used for gas service? Is any other type which is more reliable? Not able to retrieve model/tag info from existing strainer and believe these models should be obsolete by now.
RE: Strainer for gas service
http://ww
jt
2. End connections are a function of the piping design and has no impact on dirt removal. FYI, piping sizes less than 2" normally have NPT ends but flanged end models are available although maybe not as quick a delivery. Flanged ends will also have a higher total cost.
3. Something I have struggled with is the mesh size. I have finally decided that a 100 mesh screen is a resonable choice but am open to discussion by others on this forum.
4. If the service is instrument air then a filter would be a better choice unless the strainer is upstream of a filter. IA lines generally require that smaller particles be filtered than can be done with a strainer.
BTW, you cannot remove dirt down to 1 micron with a strainer. You have to use a filter.
For small filters, take a look at Peco.
