Design Table
Design Table
Design Table
I have created a sketch pattern using linear step and repeat and would like to control the number of steps from within a design table.
If I use 'edit sketch' the stepped pattern and pitch are dimensioned but the number of steps is not shown and therefore I can't pick it to add it to the design table.  The only place I can edit the number of steps is in the linear sketch step and repeat dialog box.
Any Ideas???
Thanks in advance
RE: Design Table
Instead of using the LSS&R in a sketch, create a single feature & use the Linear Pattern function to pattern the feature. The feature pattern quantities & dimensions can  be read into a DT.
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
