error in simulation
error in simulation
error in simulation
I get an error in simulation in a/view on a bicycle model. The error is when i calculate the slip angle a error is shown that there is a divisor of zero. this is probably because my model starts at zero can i start my simulation at 1 second and how is it done or can i put a constant speed on my model thanx
RE: error in simulation
You need to apply an initial velocity to each part, and you will also need an initial rotational velocity on the wheels.
right click on each part ->modify->select the obvious entry in the categories menu.
I don't know if this is the cause of your slip angle problem.
Cheers
Greg Locock
